I'm running into a problem because I'm in need of a monitor upgrade, but I have my heart set on a portrait landscape portrait set-up. My issue is that I want all 3 to support 2560 x 1440, but I can't find any monitors that would be small enough to be portrait oriented that support the 2560 x 1440 resolution.
My questions to you all is:
A - Is this set-up possible?
B - If so, what monitor(s) do you suggest?
C - Can you give me a ball park on how much this would cost? Ideally, I'd wouldn't like to go higher than 1500.
Thank you for all of your help!
