possibilites? was planning on making wired keyboard into bluetooth with battery
Mar 22, 2018
7
can I do anything with these parts I salvaged (I was going to make a USB to Bluetooth adapter with power supply but who knows)?
Intel dual band wireless card (Centrino Advanced-N 6205
56K V.92 MDC data/fax modem module (Guzzi)
MOBO Intel QM77 chipset and Intel HD Graphics 4000 with UMA graphics memory
Bluetooth module (Broadcom) with CT11 cable
Notebook Battery (not sure how to hook this up to anything)
Mar 22, 2018
7
if you glue the battery to the tooth and paint it blue, it might fit on top of the keyboard. you MUST use the data/fax modem otherwise the wireless card might not work correctly.
