Possible build. Thoughts?
Db2506
11
Hey guys. Looking for your input on this build but I have a few questions.
Here's the build I'm looking at:
http://pcpartpicker.com/list/KzgPf8
I have 32gb of RAM selected which is complete overkill for a gaming PC, I did it purely for asthetics. The way that RAM is designed, it'll give a red and white stripe look.
The case will be the new Corsair 460x, basically a tempered glass version of the 400C. Correct me if I'm wrong, but I'm fairly certain the Gigabyte Gaming 7 is an EATX board? Curious how cramped it would be in that case if thats right.
Also, I know the 860 watt PSU is overkill for now but I plan on adding another GALAX HoF edition 1070 in the future. That would be more than enough for that.
As far as LED/RGB, what fans provide decent light and color accuracy? I've been looking at the Hue+ from NZXT, Corsair LED fans, and Enermax TB Vegas fans. As far as LED strips, any help there would be appreciated.
Thoughts?
Also here's a good looking build within your budget OP which both performs better than superninja's build and is cheaper.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($324.95 @ Amazon)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.88 @ OutletPC)
Motherboard: Gigabyte GA-Z170X-UD3 ATX LGA1151 Motherboard ($122.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($66.54 @ NCIX US)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($99.99 @ Dell Small Business)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($73.99...
quality over quantity PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($227.99 @ SuperBiiz)
CPU Cooler: CRYORIG A40 ULTIMATE 83.0 CFM Liquid CPU Cooler ($113.98 @ OutletPC)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler ($96.99 @ Best Buy)
Motherboard: Gigabyte GA-Z170X-Gaming 7 ATX LGA1151 Motherboard ($190.99 @ B&H)
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory ($114.99 @ Newegg)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive ($306.07 @ Newegg)
Video Card: GALAX GeForce GTX 1070 8GB HOF Limited Edition Video Card ($499.99)
Case: Corsair CC-9011101-WW ATX Mid Tower Case ($139.99)
Power Supply: SeaSonic PRIME 850W 80+ Titanium Certified Fully-Modular ATX Power Supply ($189.99 @ SuperBiiz)
Total: $1995.97
Generated by PCPartPicker 2016-10-10 18:28 EDT-0400
You have 2 coolers on there, which one do you recommend? And what is the difference in PSUs?
Here's what you can do for that price.
If you want a pretty PC rather than a performing one, that's a different thing, but if you want a great looking PC with very meh performance over a PC with more than twice the performance, there's some priority issues there...
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive ($65.76 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($73.99 @ SuperBiiz)
Video Card: Zotac GeForce GTX 1080 8GB AMP! Edition Video Card (2-Way SLI) ($604.00 @ B&H)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($39.98 @ Newegg)
Power Supply: Rosewill 850W 80+ Platinum Certified Fully-Modular ATX Power Supply ($99.99 @ Newegg)
Total: $2037.07
Generated by PCPartPicker 2016-10-10 18:49 EDT-0400
I would hardly call 1070s in sli meh performance. I want it look good but still perform well. That build is amazing but pushing the limits of my budget. I neglected to mention that I guess in the OP. The build I have is almost maxed already. As far as Led fans or rgb strips, which brand would suggest for brightness and color accuracy?
It's a single 1070, hence why I said performance is poor for the money.
@OP, if you want, spend a bit more to get the case you want, but this is the best possible performance you're going to get in that price range. 😉
Video Card: Zotac GeForce GTX 1080 8GB AMP! Edition Video Card ($604.00 @ B&H)
Total: $1567.31
Generated by PCPartPicker 2016-10-10 19:29 EDT-0400
Total: $1567.31
Total: $1567.31
Total: $1567.31
