Possible convert wired speaker set up to wireless?
ianrobbo10
Hi guys, II have a standard hi-fi set up: Amp with record player attached, and from the amp two wired (exposed copper type not RCA) speakers. My question is, is it possible to make the speakers wireless? I would assume I'd need a Bluetooth kit with the transmitter on the stereo out of the amp, and two receivers - one for each speaker, but as far as I can tell this doesn't exist. And if it does, I imagine it'll be for speakers with RCA inputs.
Any help would be much appreciated!
To do that you would need to connect a bluetooth transmitter to the tape record out of the stereo.
You would then need an amplifier with a bluetooth receiver built in. It would be wired to the speakers so you can avoid a the long run but not all wiring.
Check out part-express.com for different options.
It will not sound as good as leaving them wired.
