Possible damage to my usb connectors
longtth
Commendable
Aug 28, 2016
So I spilled a small amount of soda on my keyboard yesterday and unplugged it immediately to clean it. Now the next day i tried to plug it in again and my computer could only register the enter key. So i plugged the keyboard into my laptop and found out that it was working perfectly, and tried the same thing with another usb socket on my desktop and found out that it worked perfectly there too. Then i plugged it back in the original usb socket where i was having problems and found out that it was working properly there too.
When i was drying my keyboard on my desk it seems some of the liquid had spilled off the desk onto my computer. There are fans on the top of my computer so some liquid might have gotten in there, even though it doesn't look like it. It looks like only a tiny bit of soda touched the sides of the case.
So my question is should i be worried that there might be some possible damage to my computer, and how should i check for possible damages.
Latest posts
