Here's the low-down on the issue I'm having:
I recently built a gaming PC from scratch and foolishly mounted the motherboard to the case without the standoffs. Initially I could boot the PC successfully, but intermittently it would fail to start when I powered on using the case switch. Only when I turned the PSU off and on again would it boot again (after a few attempts). The OS seemed to be functioning normally until I started to experience system freezes. It was at this point I realised my mistake (of mounting the motherboard without standoffs) so I dismantled and replaced mobo with the correctly placed standoffs. At this point everything seemed to be functioning great and the PC was booting normally by using the case power switch. However, after a few hours without problems I suffered a mid game freeze and from that point onwards the system failed to boot or POST. I had power to the board and fans were turning, then attempted a bios flashback but still no boot.
This was the set up.
CPU - AMD fx 8350
Mobo - Asus M5A97 R.2
GPU - XFX Radeon R9 280x
KingstonFury 2x4gb 1600
EVGA Nex750w bronze
After attempting bread boarding & basic troubleshooting with no progress I took it to my local computer shop for diagnostics using hardware swap outs. They concluded that the motherboard was shot. So RMA'd it and upgraded the mobo to the M5A99FX PRO. Received new mobo bread boarded and exact problem - no boot. However this time the mobo facilitates LED feedback for each component plugged in (solid red indicating fault) and in my case the CPU led stays continually lit. I have been through all the necessary logic tests with the board, swapped out PSU, which is functioning normally + bios flashback etc, to no avail.
So to conclude; since I'm using a new mobo and am experiencing the same problems as before, am I looking at a CPU fault? And could my mistake of forgetting to install the case standoffs have resulted in damage to both the mobo, cpu or any other components?
In addition, I've followed this guide;
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems
And this bread boarding thread;
http://www.tomshardware.com/forum/262730-31-breadboarding
Anyone recommend progression from this point?
Thanks in advance.
CPU - AMD fx 8350
EVGA Nex750w bronze
Thanks in advance.
