I’ve got a Shuttle XPC SZ87R6 case (basically a oven) with an Intel i7 @ 3.5 GHz and a GTX 970. I replaced the back fan recently and added a “fan curve” on my card using Precision.
The problem: after a bit of gaming (games like PUBG, CS:GO, The Division), the card will get hot. I’ve recorded temps up to about 70 degrees without the fan curve and it usually stays around 50/60 degrees with the fan curve (idling around 30). Then, I will eventually get the STOP error code 0x000124 (BSOD). The computer will usually reboot on its own and start up again.
I have blown out my PC numerous times, there is little to no dust. The 970 is about a year old, bought it new. This setup should be working fine.
Any ideas? Is there a way I can fix this problem, or is it simply the design of the case that is overheating the card? I have the original fan that came with the case just laying around (it works fine), should I attach it to the back of the case? I’m open to anything here.
EDIT: PSU 80 Plus 500W power supply
