Hey guys, been having some trouble with my PC recently. It's crashing on me under load a fair amount. Initially my graphics card was a HD5970 2GB, and the computer would just loose signal while playing a game. It would stay on but the video signal would cut out so, I thought it was a GPU issue. I swapped the card out for my old 768MB 8800GTX to see if it helped, but now testing under Prime95, or just trying to play Skyrim, my PC will just completely freeze with no way to do anything without holding the power button, so now I'm not sure what the problem is. My temperatures for prime95 when I had my i7 oc'd to 3.9ghz were about 80 with core temps around 84. Also my SB and NB temps even idle are about 50-54 degrees, does that seem high? I've also run memtest for hours and everything seemed ok. Any advice would be really appreciated!
My specs are:
i-7 750 @3.2GHZ
Rampage II Extreme mobo
HD5970 GPU (currently swapped out for a old 8800GTX)
4GB Corsair XMS3 DDR3 RAM.
My specs are:
i-7 750 @3.2GHZ
