I am having some issues with my computer that i am wondering if they are caused by the power supply. The issue is that the computer will occasionally turn off and then turn immediately back on. This started happening when i started turning the air conditioner on so i initially thought that there was an issue with the supply to the house. since then i have tested it on an uninterrupted power supply and it is still having the issue which has caused me great confusion. the voltage for the power supply was checked through the BIOS not through a multimeter so i am not sure how accurate the readings through the BIOS are, it was sitting at 11.9V with no load on it at all
Has anyone had similar issues and found the answer?
