Hi, since a while ago, my Motherboard has started behaving in a weird way. Here's all that has happened until now:
The first problem: When an Earthquake struck on my country, My Pc had restarted it's Time, it was changed to 01/01/2000, then I confirmed that the BIOS set Up has also restarted. That was about 2 years ago.
Months later, My computer needed to boot at least 4 times to boot properly, sometimes 6, and sometimes won't boot. This problem was fixed by taking out all of the PC parts to clean them and then installing them back in the Case.
From that moment, it needs just to boot twice to start. Not normal, but also wasn't a big problem.
Months later, I've noticed every time i disconnected my PC from a Power Supply (example, when moving it), it's BIOS goes back to default, every time.
And now, playing the overwatch beta the PC suddenly turned off because of a possible overheating. I checked the PC internally, no "Burnt" smell was found, yet when i started it, the GPU fan won't spin. 5 mins later I attempted to turn it on again and behaved normally, but as always, the BIOS was reset.
And now, not doing anything, constantly checking it's temp, it turned off suddenly again, and when came back on, my monitor won't recognize my GPU, I checked, and now neither of the CPU and GPU fans were spinning, however the fans of the case were working properly. It fixed the same way, waited 5 mins and turned back on, but this time it wasn't overheating. Also, BIOS was reset.
What it could be the cause of my PC problem?
Specs:
Motherboard ASUS P8-H61 i believe
CPU i5 3330k
GPU EVGA geforce GTX 650ti
PSU Corsair CX750
Specs:
CPU i5 3330k
PSU Corsair CX750
