Hello and thanks for any replies.
My possible issue is as follows: When I turn on my PC from a cold start, as in the power cord was just inserted into the PSU and the little switch flipped to the on position - The PC comes on, then turns off for two seconds, then comes to life. It only happens if I unplug the PC after a shut down. It doesn't happen if I restart, or shut down then start up. Only happens if I unplug the PSU from the wall.
I have no idea what would cause this as my previous EVGA NEX 750G did not do this at all. The only things I can think of are that my components aren't enough of a load for the PSU or my apartment's power isn't good enough for the 1000W at that particular outlet/line. I don't know anything about electricity though 🙁
Current components hooked up
i7 7700k@ 5.0ghz @ 1.35volts (hyper 212)
16gb corsair vengeance 3000mhz
gtx 1080 ti (founders)
4 case fans (3x140, 1x120)
2 2tb hdd
1 500gb ssd
I plan on using the evga hybrid kit on the 1080ti and maybe getting a kraken x62 for the cpu.
2 2tb hdd
1 500gb ssd
