Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: f4
BCP1: 0000000000000003
BCP2: FFFFFA8010CE6B30
BCP3: FFFFFA8010CE6E10
BCP4: FFFFF800021CF270
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\062614-32744-01.dmp
C:\Users\Squish\AppData\Local\Temp\WER-32807-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
There's the BSOD from it happening again - it's not the MoBo port, now we're checking the SATA data cable.
I'm downloading WinDbg now to debug the kernel dump.
Here's the stuff from the debugger:
Code:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\062614-32744-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is: srv*
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18409.amd64fre.win7sp1_gdr.140303-2144
Machine Name:
Kernel base = 0xfffff800`01e54000 PsLoadedModuleList = 0xfffff800`02097890
Debug session time: Thu Jun 26 03:55:59.023 2014 (UTC - 5:00)
System Uptime: 1 days 13:20:26.538
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck F4, {3, fffffa8010ce6b30, fffffa8010ce6e10, fffff800021cf270}
----- ETW minidump data unavailable-----
Probably caused by : csrss.exe
Followup: MachineOwner
3: kd> !analyze -v
CRITICAL_OBJECT_TERMINATION (f4)
A process or thread crucial to system operation has unexpectedly exited or been
terminated.
Several processes and threads are necessary for the operation of the
system; when they are terminated (for any reason), the system can no
longer function.
Arguments:
Arg1: 0000000000000003, Process
Arg2: fffffa8010ce6b30, Terminating object
Arg3: fffffa8010ce6e10, Process image file name
Arg4: fffff800021cf270, Explanatory message (ascii)
Debugging Details:
KERNEL_LOG_FAILING_PROCESS: (null)
PROCESS_OBJECT: fffffa8010ce6b30
IMAGE_NAME: csrss.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: csrss
FAULTING_MODULE: 0000000000000000
PROCESS_NAME: csrss.exe
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
BUGCHECK_STR: 0xF4_c0000005
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`03bf4e38 fffff800`02257ab2 : 00000000`000000f4 00000000`00000003 fffffa80`10ce6b30 fffffa80`10ce6e10 : nt!KeBugCheckEx
fffff880`03bf4e40 fffff800`02202abb : ffffffff`ffffffff fffffa80`127d0b50 fffffa80`10ce6b30 fffffa80`10ce6b30 : nt!PspCatchCriticalBreak+0x92
fffff880`03bf4e80 fffff800`02181f04 : ffffffff`ffffffff 00000000`00000001 fffffa80`10ce6b30 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x17486
fffff880`03bf4ed0 fffff800`01ec8e53 : fffffa80`10ce6b30 fffff800`c0000005 fffffa80`127d0b50 00000000`001a0880 : nt!NtTerminateProcess+0xf4
fffff880`03bf4f50 fffff800`01ec5410 : fffff800`01f1482f fffff880`03bf5a38 fffff880`03bf5790 fffff880`03bf5ae0 : nt!KiSystemServiceCopyEnd+0x13
fffff880`03bf50e8 fffff800`01f1482f : fffff880`03bf5a38 fffff880`03bf5790 fffff880`03bf5ae0 00000000`001a2390 : nt!KiServiceLinkage
fffff880`03bf50f0 fffff800`01ec9242 : fffff880`03bf5a38 00000000`0000d8f4 fffff880`03bf5ae0 00000000`001a1e68 : nt! ?? ::FNODOBFM::`string'+0x488e4
fffff880`03bf5900 fffff800`01ec7dba : 00000000`00000001 00000000`001a0f98 00000000`00000001 00000000`0000d8f4 : nt!KiExceptionDispatch+0xc2
fffff880`03bf5ae0 00000000`77b38e5d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x23a
00000000`001a0fa0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77b38e5d
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0xF4_c0000005_IMAGE_csrss.exe
3: kd> lmvm csrss
start end module name
I know that my SSD is AT the root of the problem, I hope it isn't the cause. I don't remember if I've appended this to my post, but I've swapped ports in hopes of it not being a port issue. It was not the case as it BSOD'd again with stop code f4, I've now since changed cables to see if maybe the cable that came with the SSD was the cause. Fingers crossed...
