Possible to Change Write Speed on XP CD Burner?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I've been using XP's CD file burner feature, but is it painfully slow.
Is there a setting somewhere to speed it up?
Where is it anyway?
jim
At what speed is it writing at??
does that match the speed of the CD's you are using??
does this match the speed of the CD drive??
peterk
It's so much easier to suggest solutions when you don't know too much about
the problem
"jim evans" <jimsnews@houston.rr.com> wrote in message
news:gj1ed1tsnkpr89mfrj7mepci3lt5hsg6aj@4ax.com...
> Where is it anyway?
> jim
How to Set the Write Speed for a CD-R Drive in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;309522
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
Get Windows XP Service Pack 2 with Advanced Security Technologies:
http://www.microsoft.com/athome/security/protect/windowsxp/choose.mspx
| Where is it anyway?
| jim
http://support.microsoft.com/?kbid=309522
Click the Recording tab, select the speed the CD recordable media will
be written ..
regards,
ssg MS-MVP
> Where is it anyway?
> jim
Thanks much for the replies.
Mine is set to "Fastest" so I guess the XP burner is just slow.
jim
> jim
It isn't that XP's burning capability is slow. The speed of the drive is
what is really important. If you have an older cd-rw drive, just go buy
a newer one. They are very inexpensive.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
In Windows XP:
Right click the D drive
Go to properties
Recording tab
Change speed to the setting that you need. 4x for most.
Its slow but should cut down the amount of errors.
