I know there are a few ways to use two routers in one home. At one point I knew what the difference between some of the ways were, but since I got my network hooked up I forgot. Well I'm redoing my network and I wanted to know the possible ways of using two routers. My purpose is so that the downstairs gets good wifi signal and so does the upstairs.
What I am looking for specifically is a way to use the two routers on the same SSID while at the same time not losing bandwidth in my network. I remember that is possible, is it? I have no problem using a wire to connect the two routers. I just want them to both be the same SSID so I don't have to switch networks constantly, and I also want to be able to do so without losing bandwidth.
My main router is a router/modem combo from Century-Link/Qwest
My Secondary is just a router.
I can provide model info if needed 😀
Help me out? Please.
Thanks!
Eli H.
Thanks!
Eli H.
