I managed to spill some liquid in my homebuilt machine. I would like to say I was able to cut power before any damage happened, but I apparently was not. After drying it out, the first thing that POST let me know was wrong was the graphics card. I replaced it with an older model I had around. Now, the computer will post and will occasionally even get to the windows startup screen. However, it won't get past there, and it fails at a random time; sometimes during memory enumeration, sometimes before then, and sometimes after, but it's never gotten to the Windows login screen. None of the LEDs power off or anything, so I'm not sure that it's a power supply failure. It's an older CPU socket so in order to replace either the motherboard and CPU they will have to go together. I unfortunately don't have access to any testing equipment.
What should I replace next? The power supply or should I bite the bullet and get a new mobo/CPU?
Update:
Unfortunately, I'm not sure where the liquid (which was alcohol plus a diet soda) went, and there's no integrated graphics, so without the card it's just beeping at me. I did some testing this morning after giving it more time to dry out; all the random reboots appear to have stopped, and Windows is stuck at classpnp.sys. It looks like this is probably a BIOS problem; I did clear the CMOS to be safe before when it wasn't working, so I think I may have to switch the SATA controller back to something that's friendly with my SSDs. Hopefully this will get me back to booting, and then I can make 100% sure the old graphics card is dead, and go about getting a new one if so.
Update:
