Hello once again,
this forum has been very helpful recently in overcoming my PC building shortcomings, I'm turning to your advice once again.
I've tried to give my CPU a mild overclock of 4,5GHz just to squeeze in that extra power and to see if my cooler is capable of handling it. I've raised the vCore to 1.2V and tested it with Prime95. After a few minutes, the CPU underclocked itself to 3.5GHz, the temperatures at that time were steadily reaching 71*C.
After searching the internet for a while and trying various things (Turning off XMP, raising the voltage, lowering the clocks, turning off SpeedStep...) I've come across a similiar post which hinted at raising the Long and Short duration power limit in the bios to max. I've done just that and ran Prime95 for an hour or so.
This seemes to resolve the problem. The clocks stay at 4500MHz and the highest reached temperature is 79*C which - while not optimal - is more than expected considering my not so powerful cooler. What's more, after reaching that thermal apex, the temperatures seemed to lower down to 69*-72*C and stabilized around that range.
Although the problems seems resolved, questions remain:
Can I hurt my motherboard or CPU by raising the power limits? Is maximum of 79*C in Prime95 comfortable? I'm a complete beginner to overclocking so excuse the basal questions.
P.S.: As of now, I have the Intel SpeedStep turned off, should I turn it back on?
Specs:
MB: MSI Z370-A PRO
CPU: i5 8600k @ 4.5GHz
Cooler: SilentiumPC Fera 3
GPU: Gigabyte 1070 Ti
RAM: Kingston HyperX Predator DDR4 16GB (2x8GB) 3200MHz CL16
HDD: Seagate Barracuda 1TB
PSU: Corsair RM750x
tldr: Had to set my Long/Short duration power limit in my BIOS to max in order to not let my CPU underclock itself while stresstesting. Voltage is relatively low (1.2V) and OC is very moderate (4.5GHz). Will it cause me any problems in the future?
Specs:
MB: MSI Z370-A PRO
PSU: Corsair RM750x
