Power button not working, checking compatibility
drewderman
7
Nothing is happening when I try to power on my newly built computer. Are my motherboard, RAM and processor incompatible?
I have the following components:
Motherboard:
ECS B85H3-M(1.0) LGA 1150 Intel B85 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135355
Processor:
Intel Core i7-4770 Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I74770
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116900
RAM:
Team Vulcan 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model TLD38G1600HC9DC01
http://www.newegg.com/Product/Product.aspx?Item=N82E16820313355
all the three components u have mentioned are compatible with each other. check if the power switch jack is properly connected to your motherboard.
Hey c4, the power switch jack is in the right spot on the F_Panel header. I thought that was the problem before and have tried turning around the jack to swap the positive and negative in case I installed it backwards, but that did not work.
I hooked up the PSU and power switch to another computer and they worked fine together, so the power supply does not seem to be the issue.
Do you think that the Motherboard is just DOA?
Thanks!
