Question Power button on Motherboard (ASRock B365M)
Jan 6, 2020
4
Hi guys!
I'm nearly done with putting my new PC together. I've had a very old Optiplex 3020 MT case and replaced the motherboard and most components with the ASRock B365M Phantom Gaming 4 motherboard.
Now I'm stuck with the power button and where to plug it in.
I got this cable:
View: https://i.imgur.com/VqAoMA7.jpg
- it has 2 holes at the top and 3 holes at the bottom.
This is the motherboard:
https://www.goldfries.com/images/hwreviews/2019/asrock_b365m/asrock_01.jpg
I did check the manual and I can see the "System Panel Header". Am I right to line up my cable with:
Top row: "PWRBTN#", "GDN"
Bottom row: "GDN", "RESET#" and "GDN"
EDIT: Ok after trying my luck with just plugging the cable in - I can't. The only way to fit it onto the motherboard would be by flipping it and just connecting 4/5 pins.
If anyone can help - that would be awesome. Stuck here.
Any help is much appreciated!
Dom
