Hi Guys!
I'm having a rather strange issue in my partly new setup. My PSU (Enermax Liberty ELT500AWT) won't start by pressing the power-button on the case when it is screwed into the case (Fractal Define R5 Black). I have to connect the green wire to one of the black ones on the ATX 24-pin connector so that the PSU starts and I then can press the power-button to start the PC. I tried out another PSU this weekend and with that one the power-button works without any problems, so the case should be fine. Now comes the strange part, I left the other PSU screwed into the case (completely unplugged) and put mine on top of my PC, and put some plastic in between so it wont scratch the case. Plugged everything in and the PC started using the power-button. Ran the PC for a couple of hours like that and then decided, to put my PSU into the PC and surprise surprise the power button didn't work "normally" anymore. The very same PSU works without any issues with another case and Motherboard.
Is there some pins i have to set? I'm 100% sure I got the PWR_BTN pins correct on the Motherboard, as I've checked those multiple times. Does someone have any idea?
Would it be safe to run the PSU without a connection to the case over a long time period? Or was I nominated for the Darwin award while running it with plastic in between case and PSU?
Best Regards
SalzBrezel
PSU: Enermax Liberty ELT500AWT
MB: Gigabyte GA-H81M-D2V rev 2.1
Case: Fractal Define R5 Black
Best Regards
SalzBrezel
