I just bought a secondhand graphics card. Unfortunately I lost the power cables that came with my power supply, which is a Corsair CX650m. What cable do I need?
Thanks man!https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/Power-Supplies/Type-3-Sleeved-Black-PCIe-Cable/p/CP-8920111
You can buy most cables you need for Corsair PSUs from their site. It looks like yours should use the Type 3 cables. The link above should be the exact PCIe cable you would need if that GPU requires one however you can always email Corsair support and I am sure they would verify that for you.
Thanks! This one is even cheaperhttps://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/Power-Supplies/Type-3-Flat-Black-Ribbon-Cable-PCIe-6+2-pin,-single-connector,-Compatible-with-all-type-3-pin-out-PSU/p/CP-8920130
Type 3 Flat Black Ribbon Cable PCIe 6+2 pin, single connector, Compatible with all type 3 pin out PSU
$3.99
