Question Power Cable for Video Card
Aug 13, 2022
I am buying the MSI Gaming GeForce RTX 3080 Ti I am also buying RGB Power Cables to go alone with it my Question is do I need a Double 8-pin or a Triple 8-pin ...?
bignastyid
What makes is the 3080ti your talking about different manufacturers use different spec the msi 3080ti all I can find is a dual I'm not saying your wrong I just can't find anything that supports msi 3080 to needing 3 all I'm find is msi 3080 with two
The MSI Ventus only has 2 8-pins but the MSI gaming trio and x trio(aswell as the Suprim) models have 3 8-pins.
https://www.msi.com/Graphics-Cards/Products#?tag=GeForce-RTX™-3090
Where the OP called it the Gaming then it is most likely a 3 connector card. But it never hurts to verify by asking for more info.
@Patrick Castor Do you have a link or atleast the full model name of the MSI 3080Ti you are looking at?
Reactions: white.a.drew
