Hello,
I have a 1000w power supply and was wondering if it is OK to hook up Blu-Ray Burner, and two 1TB hard drives to one Cable/Dongle that has 3 Sata connectors on it. below is are the hard drives.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533&cm_re=western_digital_1tb-_-22-136-533-_-Product
Also it is ok to hook up two ATI 5770 Sapphire Vapor-X in crossfire setup to one cable/dongle that has a 6 pin and one 6pin+2pin, or should they have their own cable. Each video card requires one 6 pin connector.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102868&cm_re=sapphire_5770-_-14-102-868-_-Product
Thanks
Thanks
