[SOLVED] Power Cable RX580 8G
Sep 17, 2019
5
New to building PC's, Graphics card XFX Radeon RX580 8G shipped with an 8 pin power cable that branches into two 6 pin connections. Do I install two 6 pin cables back to the Power Supply? If so, does it matter which 6 pin connections on the PS (Corsair CX450M) that I use?
Thank you for your reply. The GPU has an 8 pin connector so I used the PCIe 6 +2 connector to the card and the other end went to a 6 pin connection on the PS. Is that correct?
