Power cable with different characteristics
walalon
I have a N552V asus that uses a 19V 6.32A 120W power cable but I can't find a cable with that characteristics anywhere. If I wanted to try different one, which things can vary and not damage my laptop? W, A, V?
Are you looking for a new power brick? Or just a replacement cable from the wall to the brick? The output cable, carrying the 19V is not user serviceable (not without voiding the warranty)
Google the model number on your power brick and if there is a replacement you should be able to find something. That's how I found a replacement power brick for my alienware laptop.
If you are speaking of the ac adapter, the voltage (19V) needs to be the same, and the amperage (6.32A) should be the same or higher for it to work properly.
