cpu-i5 6400
gpu-Power color reddevil rx 470 4gb ddr5
motherboard-asus h110m-k
ram-kingston hyper 8gb ddr4 ram
psu- SeaSonic M12II 520 Bronze EVO Edition(my psu power cord is faulty which i will change(earthing issue))
harddisk-1 tb western digital
case-corsair carbide spec 2
fans-1 front motherboard controlled ,1 rear fan full rpm mode from psu connection
so it's now 16 days i am using that gpu so the problem is that before installing my gpu my case was running cool so after installing that gpu my temp sometimes goes to 40 like playing tomclancy the division -uplay account for 2 hours continuously, my temp sometimes goes to
1-motherboard-35-40
2-cpu-35-40
3-gpu-highest 61
idealing is fine in my pc it's around cpu-motherboard -27-30 highest
my gpu always ideals at 50-51 after game-play with fans automatically turned off and normal idealing is 45-50
So the main problem is that when i start gaming my gpu makes some weird noise like trrrrrrr which i came to know is coil whining from youtube which i am not sure it sounds same as coil whining but the main thing is that case side pannels heats up a bit when gaming/gpu load so is everything fine ? any rx 470 user faced the same issue ?i reported to my local shop but they are little bit slow
1-motherboard-35-40
2-cpu-35-40
3-gpu-highest 61
