Question Power connectivity problem with EVGA NVIDIA GeForce RTX 3070 Ti FTW3 ULTRA GAMING 8GB ?
Sunshyn
6
I just got my EVGA RTX 3070 Ti but the power supply in my old card had 2 6+2 pin plugs. The new RTX 3070 has two 8 pin plugs. That apparently didn't work and I need to find a cable for 12 pin pc1e to 8 pin.
What do I need for a cable for my Be Quiet! Power Zone 750W? I'm running into problems finding the right cable. Am I going to need a new PSU?
EVGA Z370 FTW
Intel i5-8600k
EVGA RTX 3070 Ti
case - Fractal Design Define S
Windows 10 Pro
cooler - Rosewill ROCC-16003 - 92mm
G.SKILL Aegis 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 2666 (PC4 21300)
Directly from EVGA's website:
https://www.evga.com/products/product.aspx?pn=08G-P5-3797-KL
Requirements
  • Minimum of a 750 Watt power supply.
  • Two available 8-pin or 6+2pin PCIe power dongles
  • Total Power Draw : 290 Watts
I have a 750w PSU, but the 6+2pin PCIe power goes to a pig tail and doesn't seem to work. I'm thinking I might need a new PSU since this one has been with me for a couple systems. So I'm now looking into which PSU I'd be best off going with (having blown through my budget).
