There are no 28 pin connectors . I am sure your connector is actually just a 20+4.
The connectors come in 20, and 24 pin, the 20 pin are older ones, the new 24 pin +4 is there for extra power and another phase for the CPU.
THE PSU may have a 28 pin connector
"There are a total of 28-pins where the cable plugs into the PSU's modular interface, instead of the usual 24-pins. The extra four pins are "sense wires". While a +3.3V sense is part of the ATX standard and is found on most PSUs, it is not often implemented. The RMi not only utilizes the +3.3V sense on the ATX connector, but also utilizes an additional +12V sense and +5V sense. These sense wires read the voltages at the load (the end of the cable) and can increase voltage automatically if voltages drop" -
Blackbird
