No one can answer the question based on the inormation provided.
For a given system a PSU rated at say 500W verses a 1000W PSU for the same system will draw very close to the same wattage at the outlet (within about 10%)
To detirem your wattage:
.. For a good estimated, take your GPU and google it for a review, most reviews will indicaet "system Power" both at idle and at load. This will generally be a little higher than what you will have. divide that by the Effiency rating for the PSU, if unknown use 70% and that will approximate your Power consumption at the wall.
For most with a GPU =< 7870 your power should be around 100W @ idle and 300->350 watts loaded.
IE My system has a 7850 GPU, googling it I find that my system power should be 220->290 Watts (Loaded) which would be less than 400 Watts . My measured power was approx 300 Watts (If I remember correcly).
NOTE This is ONLY for the computer and des nOT include monitor/scanner/printers.
http://www.anandtech.com/show/5625/amd-radeon-hd-7870-ghz-edition-radeon-hd-7850-review-rounding-out-southern-islands/17.
To determine exacty, as J_E_D_70 stated buy a watt meter - Newegg often has the Killawatt on sale for around $15.
I use Furmark to load system, which is generally slightly higher than runing a game.
