J Jason Man Reputable Sep 23, 2014 27 0 4,540 Oct 5, 2014 #1 Help for power for 6 r9 280x will 2 100w psus be enough? Thanks
Solution TopLuca Oct 5, 2014 I assume that's for mining well here's the TDP for the 280X : 250W So Total for 6 will be : 6x250 = 1500W So 2x 1000W from a reputable brand should be enough for the entire system.
TopLuca Splendid Jun 2, 2012 3,119 0 21,960 Oct 5, 2014 Solution #2 I assume that's for mining well here's the TDP for the 280X : 250W So Total for 6 will be : 6x250 = 1500W So 2x 1000W from a reputable brand should be enough for the entire system. Upvote 0 Downvote Solution
J Jason Man Reputable Sep 23, 2014 27 0 4,540 Oct 5, 2014 #3 will azza titans work? Upvote 0 Downvote
TopLuca Splendid Jun 2, 2012 3,119 0 21,960 Oct 6, 2014 #4 I don't know what are you referring to. Upvote 0 Downvote
ZeusGamer Admirable Jul 9, 2014 1,647 1 6,165 Oct 6, 2014 #5 I've got two R9 280x's and I've monitored them using a my friends PSU 860i and I'm maxing about 750 with everything overclocked. i7 4770K to 4.55 Ghz x2 R9 280x to 1.2 Ghz Upvote 0 Downvote
J Jason Man Reputable Sep 23, 2014 27 0 4,540 Oct 6, 2014 #6 is the azza titan psu good? Upvote 0 Downvote
ZeusGamer Admirable Jul 9, 2014 1,647 1 6,165 Oct 7, 2014 #7 Jason Man : is the azza titan psu good? I've never heard of that PSU before. Generally, you want to stay within trusted brands man. Upvote 0 Downvote
