Archived from groups: comp.sys.intel,comp.sys.ibm.pc.hardware.chips (
More info?)
On 15 Nov 2004 17:17:03 -0800, yjkhan@gmail.com (ykhan) wrote:
>Intel quietly introduced the latest Prescott, a 3.8 Ghz chip with the
>NX-bit support available (that's why it's got the "J" designation).
>They seem to have introduced a new, improved halt state to keep things
>cooler.
>Intel's Pentium 4 570J 3.8GHz processor - The Tech Report - Page 15
>http://techreport.com/reviews/2004q4/pentium4-570j/index.x?pg=15
I think the actual CPU consumption is probably lower than that by
maybe 50%? He's measuring at the wall plug after all and that would
include the PSU inefficiency (measured at 80% 250W, 76% 150W by some
website before), the extra stuff like motherboard, hard disk, graphic
card, RAM as well as the motherboard voltage regulator's inefficiency
(say 85%), so that's 242*0.8*0.85 = 164W at most for load and 130 *
0.76 * 0.85 = 84W.
Comparing that against a Prescott we're playing with overclocked to
3.8 with much higher than default vcore. The processor's idling power
draw is pretty much in the 4~5A 12V range, which puts it at 60W x 85%
motherboard regulator efficiency to 51W. The 3.3V and 5V used mainly
by the motherboard and RAM takes a consistent 25W, while the
connectors going to the hard disk, graphic card takes around 20W or
so. That would put us at around 96W.
But our vcore is like set to about 12.6% higher than the default
around 1.39V so that makes dynamic power 27% and static power 43% (did
I get that right from the previous power discussion?) higher than a
default processor from Intel. Assuming static is 40% and dynamic is
60% of power consumption, this makes a difference 33% or 13W from 51W
(51/1.33). So we should be seeing some 83W on idle, viola, same
ballpark figure
For load, we've got almost the same figures for non-CPU items, just a
bit higher on the 3.3V since the RAM are active. Make that 50W for
these stuff. The processor is drawing around 14~15A so that's 180W x
85% = 153W and adjusting for vcore, the default processor should be
seeing some 115W, which is way off from techreport's. But incidentally
is also Intel's TDP for a 3.8G processor
Comments anybody? Why is there such a huge difference in the load
power even though the idle is pretty close? Or is my speculative maths
just really bad?
L.Angel: I'm looking for web design work.
If you need basic to med complexity webpages at affordable rates, email me
Standard HTML, SHTML, MySQL + PHP or ASP, Javascript.
If you really want, FrontPage & DreamWeaver too.
But keep in mind you pay extra bandwidth for their bloated code
