M miha2 Distinguished Aug 14, 2009 525 1 18,995 Aug 11, 2010 #1 Hello everyone. Given the components: Phenom II 955 (oc'ed to 3.6) and, let's say, ATi's 5850. What's the proper Power Supply for this combo? Max fan would be Coolermaster V8. Or any other alternatives that are cheaper but better?
Solution Timop Aug 12, 2010 The phenom 955 OCed draws 150W, while the HD5850 draws about 130W on load even when you account 50W from everything else, its just 330W.
Timop Distinguished Feb 27, 2010 3,070 0 21,160 Aug 12, 2010 #2 An decent 400W would even do it, but if you want to crossfire that HD5850, go for a quality 650W. Upvote 0 Downvote
Henry Chinaski Distinguished Mar 16, 2010 1,040 0 19,460 Aug 12, 2010 #3 I recommend you a quality 500W PSU with one 8-pin and one 6-pin PCIe connectors. If you are thinking about doing 5850CF with two cards, then go for a quality 600W PSU with two 8-pin and two 6-pin PCIe connectors. You can find very good options in the PSU Review Database (see my signature) Upvote 0 Downvote
M miha2 Distinguished Aug 14, 2009 525 1 18,995 Aug 12, 2010 #4 sure it will be enough? don't forget - it'll be OC'ed to 3.6 (maybe to 3.8, but most probably to 3.6) Upvote 0 Downvote
Timop Distinguished Feb 27, 2010 3,070 0 21,160 Aug 12, 2010 Solution #5 The phenom 955 OCed draws 150W, while the HD5850 draws about 130W on load even when you account 50W from everything else, its just 330W. Upvote 0 Downvote Solution
M miha2 Distinguished Aug 14, 2009 525 1 18,995 Aug 12, 2010 #6 Timop : The phenom 955 OCed draws 150W, while the HD5850 draws about 130W on load even when you account 50W from everything else, its just 330W. That is exactly what i wanted to know. thank you. Upvote 0 Downvote
M miha2 Distinguished Aug 14, 2009 525 1 18,995 Aug 12, 2010 #7 Best answer selected by miha2. Upvote 0 Downvote
