D dani80008 Prominent Feb 11, 2018 29 0 530 Mar 2, 2018 #1 uhhh, i'm getting the RX 580 8gb, and i'm wondering if my power supply is enough. it's the SeaSonic 400W Active PFC 80+ SS-400ET PSU, is it okay, or i need to upgrade or something?
Solution Dark Lord of Tech Mar 2, 2018 A Radeon RX 580 needs 27 amps on the 12v+ rail and at least a 500w-550w power supply , usually with 1 - 6 pin and 1 - 6+2 pin PCIE power connections.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Mar 2, 2018 Solution #2 A Radeon RX 580 needs 27 amps on the 12v+ rail and at least a 500w-550w power supply , usually with 1 - 6 pin and 1 - 6+2 pin PCIE power connections. Upvote 0 Downvote Solution
Susquehannock Honorable Dec 8, 2016 869 1 11,365 Mar 2, 2018 #3 The PSU lacks the power and connector you need for that card. Upvote 0 Downvote
