Power down after 30sec or so
G
Guest
Guest
I messed with the bios setting on an old GA-945P-s3, trying to get it to take my newer E8400 CPU.
I did not get that working and when I put the old CPU back in, and pulled the power/battery on the mother board to reset, system powers down, about the same time I get back int o the BIOS screen to reset.
Any idea what I can do?
thanks in advance
d1rtyju1c3
874
Shut the system down, remove battery for 30sec, re-install battery and power on the computer. Also bios ffd may support the E8400 according to gigabyte, you might try to update the bios. Remember dont update through windows use Q-flash in the bios and read the manual it will tell you how to update through Q-flash.
G
Guest
Guest
BY GUM IT WORKEd, the old intel 1.8 is back in and I have windows up.
what is bios ffd?
I'll read the manual and look at this q flash thingy
thanks again
But in closing that chip E8400 should work with that board GA945P-s3, correct?
d1rtyju1c3
874
That is a newer bios that supports the E8400, so it should work if the bios is updated to the ffd bios. Download and install CPU-Z in the motherboard tab it should tell you what bios you are using.
It may tell you what the bios is on the post screen or in the bios .
G
Guest
Guest
im rev 1.0ooks like a new mother board for me
For the E8400:
this
GA-EP45T-UD3LR w/ DualDDR3 2200+, 7.1 Audio, Gigabit Lan, PCI-E
or this
Gigabyte GA-EG45M-DS2H w/ DualDDR2 1066, 7.1 Audio, Gigabit Lan, 1394, PCI-E, HDMI, Blu-ray
SKU: MX22160 Part#: GA-EG45M-DS2H
