Archived from groups: alt.sys.pc-clone.dell (
More info?)
On Fri, 1 Apr 2005 09:34:26 -0500, "Ted Zieglar" <teddyz@notmail.com>
wrote:
>The power supply itself was $30 plus shipping. Dell automatically adds
>next-day delivery ($16) since they presume that if you're ordering a power
>supply you need it asap, but you can ask for a slower, less expensive method
>if you like.
>As long as I was going to replace my power supply, I thought I would go with
>a fancier unit from a third party. Dell uses a proprietary power supply, but
>there are ways to adapt a standard unit to fit the 4500. If you decide to go
>this route, search the internet for the model number shown on the label
>attached to your Dell PSU. (Don't confuse the model number with Dell's part
>number, or the bar code number.) That provided links to several suppliers
>with compatible units and adapters to make them work with your motherboard.
>The thing is, these third party units cost twice what Dell was asking. And
>Dell's PSU is guaranteed by Dell to work in my computer. So in the end I
>went with Dell. If the replacement is like the original, then by the time
>the replacement starts getting noisy it will be time to buy a new computer
>anyway.
>Ted Zieglar
><Rob> wrote in message news:93eq411kg275druikmk8hfuls141f32hvc@4ax.com...
>> On Thu, 31 Mar 2005 10:01:58 -0500, "Ted Zieglar" <teddyz@notmail.com>
>> wrote:
>> >I bought a replacement power supply unit from Dell for my Dimension 4500.
>It
>> >was real easy. The Dell part number on my original PSU was 0N380, and the
>> >Dell rep said she couldn't get that particular part so she substituted a
>> >unit with Dell part number 2N333.
>> >I looked up both part numbers on Dell's web site and their description is
>> >the same, except for one difference: My original PSU was "non-Power
>Factor
>> >Correction" and the replacement is "Power Factor Correction". What is the
>> >difference?
>> >Ted Zieglar
>> Ted, just curious, what did it cost from Dell? I've also got a 4500
>> and may end up doing the same thing down the road.
Thanks Ted, appreciate the info. Not sure which way I'll go because
it hasn't happened yet but I think right now I'd go with the power
supply but maybe not by next year??? In any case, I'm saving your
post for future reference "just in case" <grin>.
thank you again.
