I went through 4ryan6's 2012 fan roundup and decided to buy a couple of Cooljag 120 and 140mm fans. Of course, having something to compensate for, eh hum, <cough>, excuse me, I saw that Cooljag offered a higher CFM 140mm than 4ryan6 reviewed and had to get a couple of those. BTW, I bought them directly from Cooljag as I live 15mi away and they charged an arm and a leg $18 compared to FrozenCPU's prices.
I want to mount one of the 140mm Cooljag F121425BU in a Antec One Hundred case with an Asus P8Z77-V Deluxe. This fan can draw up to 1.1 amps, which is a bit much for a MOBO header. Asus only lists the current rating of the CPU_FAN header, which is one amp, and not any of the other five headers. Asus' tech support doesn't know the difference between electric current (measured in amps or joules) and electric potential difference (measured in volts), so the only answer I've gotten so far is "12v."
My idea is to power the fan directly off the PSU, but use the MOBO header to obtain and control fan speed. Anyone done this, and if so what were your experiences and what should I look out for?
Thanx for your input on this.
Cheers
Cheers
