power for 1 sec than nothing
pike
Splendid
Nov 10, 2001
7,878
Hello
I've set up a small sys with new mobo new vid and new psu. When i switch on the power it goes to the cd roms lights but in less than a sec the power cuts off.
Would a faulty mem stick do this?
Any suggestions
thanks
dany
<font color=green>"Nothing is good or bad, it all has to do with intentions!"</font color=green>
Are all the cables plugged in the right way?
Is the clear CMOS jumper in the correct possition? I remember once I left it on clear CMOS, and my comp would start up for 8secs, then turn itself off.
Have you got a spare memory stick you could try in it?
P4c 2.6@3.25
512Mb PC4000
2x120Gb 7200.7 in RAID0
Waterchill KT12-L30
Abit AI7
Radeon 9800Pro
Sounds like a shorted motherboard. You probably have a mounting post between the 3rd and 4th slot, with no hole in your board there. This is the most likely location because 1/2 of motherboards use a stud there, while the other 1/2 don't.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
You could also check that the heatsink is mounted correctly - if the CPU core is not contacting the HSF then after a very short time the CPU will overheat and the burnproof function on the board will shut off your PC instantly...
4.77MHz to 4.0GHz in 10 years. Imagine the space year 2020 :)
