power for 750ti
Niteesh DRANGO
51
Hello guys,
My brother brought me an gtx 750ti.but my problem is my smps is an Acer PC one, which came with my acer pc. My PC is m600 h61. Which has :
i3 3240
Ecs h61mv
4gb 1333 ram
And my smps says 200w in it.when I checked my setup with the GPU it says 199w so should I change my smps or carry on with it.if I could continue how can I connect the card I will not be overcloacking the card I thought of using 2 molex to 6 pin and connect it or suggest me another way.
Is corsair vs450 a nice one or suggest me nice cheap one
If your GTX750ti is a factory overclocked version which requires a 6 pin pcie power connector, it will draw up to 150 w by itself.
Do not attempt to use it.
If your GTX750ti does not need a aux 6 pin power connector, it will run on the pcie slot power which is 75 w max, and you could try it.
