Archived from groups: alt.sys.pc-clone.dell (
More info?)
For some reason, the voltage isn't stated on the speakers.
I've set it about 6 and it seems fine.
thanks!
"JLA ENTERPRISES TECHNOLOGIES INTEGRATION" <info@jlaenterprises.com> wrote
in message news:IwHJc.155246$2o2.8573189@twister.southeast.rr.com...
> Hello,
> If there is no voltage label next to the jack for the AC adapter, try
a
> simple 6V - 9V small AC Adapter that has the right size plug for your
> speakers. This most likely will work. If it is too weak, you will see
the
> power light on the speakers either be very dim or noticeably flicker at
> higher volume. If it is too much, you will also be able to tell in most
> cases. At that voltage, I would doubt that this range would be too much.
> If you are in the Raleigh area, give us a call and we would be more than
> glad to give you one as we have alot of spares.
> Technical Support Team
> Check out some of the items we are offering
> Dell Docking Stations starting at $5.00
> Dell 21" Flat Screen Monitors starting at $40.00
> Dell Latitude and Inspiron CD Rom and Floppy Drives starting at $5.00
> Be sure to visit
http://www.jlaenterprises.com
> "Tony" <poiwerpoipoi@poipoipoi.com> wrote in message
> news:cd7bjo$3r$1@hercules.btinternet.com...
> > I have PC speakers, but no indication of what voltage my adaptor should
be
> > set at.
> > They are small, and don't have an external amp. I wonder if anyone knows
> > what is the best voltage to power them at.
> > thanks
