Power Graphics Cards With Split Connectors ?
If you mean only plugging in 1 connector to each card when you need two for each, then no. You need to have both plugs plugged into your GPUs otherwise you'll see crashes when the GPU is under load if it even turns on. You could try molex to 6 pin converters, but it won't be as stable.
