I have an old server which I got from my work to fixup and place in the serverrack to do fun stuff with. It's a write-off for them but good enough for me
It's a DL360 G6 with 1 backplane and I want to connect 6 disks... Which leaves me negative two spots. A new backplane with cables is around 40 euros on ebay so this is still a possibility but I just realised there may be a cheaper option.
I've seen there are Mini-SAS to Sata cable for like 15 euros which leaves me with the power to sort out.
Which would be easy because I have a 6 pin male (PCIE) to 2 * 3 pin molex cable hanging around the house so I thought why not just do a male male molex on it and hook a molex to sata on the disks. I would be done withing 20 euros.
(FYI the only power connector is on the motherboard and that's a 6 pin female.)
But when I was searching for a Molex to Sata they where all 4 pin molex connectors but the connector on the PCIE cables are only 3 pin molex.
Does this even matter? Or should I not bother with the connectors and just buy a HDD backplane and cables instead?
TL;DR
Can you power a HDD over a 3pin molex connector?
The cable I have with the molex connectors looks like this:
PCIE to molex amazon link
TL;DR
