Purchased a EVGA GTX 750 Ti a few days ago. Installed it. Its very unstable and I think it might be power supply problem. After doing some digging around I've found out that it requires 20 amps, but my power supply is only a 17 amp on a 12 volt rail. The power supply itself measures at 480watts and has 2x 12 volt rails.
Will buying a +12v 20amp power supply fix this problem? I'm guess so.
My other question is, is the 6pin video card connector from the power supply going to be what I use, or will I need to use one that connects from another cable from the power supply such as the molex connectors?
