Power LED Not working anymore.
sirenssixx
18
So I just built my new computer a little over a month ago. It's working perfectly, and when i first started using it the LED's were working well. But just today i noticed that my power LED isn't working. Everything is running smoothly, nothing has crashed, i've seen no signs of problems with my motherboard or anything. It simply stopped working, then it came back on for a few seconds, and then went off again. I shut off the computer and checked the P.LED connectors and everything seemed fine, i put them in the way my manual told me too. Could it just be a faulty lite? since every other led is working just fine.
My motherboard model is Gigabyte GA-H87-D3H
My case is a NZXT Phantom 410.
I'm worried that it's a motherboard shortage, I'd actually be happy to hear that it's just a bad lite.
If it is a motherboard problem , is it anything i should be worried about? This is my 1st computer that i've built myself and im not quite sure how to handle the situation.
what do you mean by using it?. The other leds are working just fine, im looking at them right now. it's just that 1 that isn't turning on anymore.
