Power Loss Protected SSD
  • Thread starter Thread starter Deleted member 2234508
  • Start date Start date
D
Guest
Any ssd with power loss protection?
I'm looking for one with Capacity: 120gb - 180gb and Price: <100 euro.
Thanks in advance!
The only ssd out there that claims to have power loss protection is the WD green 120gb (and 240gb if someone interested) for less than 100 euros / dollars, but i'm not sure if that true. Here ( https://support.wdc.com/knowledgebase/answer.aspx?ID=17070 ) is the wedsite that claims so.
Also, i'm not interested in high performance as i'm going to use it in an old system with SATA 2 port.
With a UPS you are not protected. You are protected against power failures but you are not protected against unexpected power-loss. The difference is that all loss of power without a prior STANDBY IMMEDIATE command, counts as unexpected power-loss. This includes pressing the reset button, restarting from the BIOS, crashes/bluescreens and even tidy shutdowns are known to cause this by bad power-off timing.
