M malinbuddhika Dec 16, 2018 4 0 10 Dec 16, 2018 #1 When I plug my computer it's automatically on what is the reason about that
Solution Wolfshadw Dec 16, 2018 The power wires from the front panel are probably shorting or are crossed. -Wolf sends
D drea.drechsler Champion Oct 16, 2017 9,841 2,647 54,790 Dec 16, 2018 #2 When did this start happening? Upvote 0 Downvote
M malinbuddhika Dec 16, 2018 4 0 10 Dec 16, 2018 #3 drea.drechsler : When did this start happening? Nothing normally on is it good or bad I want to fix it Upvote 0 Downvote
Wolfshadw Titan Moderator Aug 3, 2006 28,223 1,514 133,290 Dec 16, 2018 Solution #4 The power wires from the front panel are probably shorting or are crossed. -Wolf sends Upvote 0 Downvote Solution
M malinbuddhika Dec 16, 2018 4 0 10 Dec 16, 2018 #5 Wolfshadw : The power wires from the front panel are probably shorting or are crossed. -Wolf sends I checked it and replied. Thanks Upvote 0 Downvote
