Hello. thank you in advance for your help
i have a socket 1366 motherboard, specifically ex58 extreme by gigabyte with a core i7 920.
when i turn on the pc, it wont start. all the fans/leds etc will work, but pc wont start. the motherboard has a number indicator of the problem, and it shows 88 but all leds are turned on, not like the number for the problem is 88 but its like all the posible lights on the led indicator are turned on (hence the 88), plus there is no troubleshoot for number 88.
but when i turn the pc on via the motherboard on button (not the case) sometimes this happens:
it starts normals, and tries to work (number others than 88 are shown on the led) but then it either turns off completely, or turns off then restart, but showing 88 again 🙁
if i turn it on, and when it shows 88 i turn it off, over and over again, there is a time when it starts normally, with other numbers, not 88, but ff. and it works normally, no problems.
but its a pain to continue like that plus idk if it will broke soon 🙁
what do u think it can be? motherboard? case on-off swtich? power supply? ty 🙁
