G
Guest
Guest
I just recently fixed the cord on my power strip because the ground post thing was gone, did this so the surge suppression would work and I can hook up a PC to it. I then tested it with a tester and the outlet itself did not have a ground connection. (I tested the tester it with a 100% known grounded outlet) My dad explained to me that our ground wire is connected to our neutral at some point in the breaker box and at the electric pole outside.
My question is, Can we then, in theory just connect the neutral and the ground with a jumper or will that energize the ground post in the plug when a load is applied? My dad will help me with anything I need to do as I am only 13 (yes it complies with the ToS)
and I don't particularly like messing with lethal voltage.
Code:
BOM does not permit children under the age of 13 to become members, post home pages or web sites on our service.
