Power problem gtx 960
Feb 1, 2019
I have a power supply with dual 6 pin and I bought this card used so I dont have an adapter and all the adapters I look at online look like they dont fit. Could someone link me a dual 6 pin to 8 pin adapter that fits a gtx 960 please and thank you.
Dark Lord of Tech
Speedy Gonzales
Best bet is to get a decent PSU , but here are a few options below.
https://www.ebay.com/p/NVIDIA-Dual-6-Pin-to-8-Pin-PCI-E-Graphic-Card-Power-Cable-Original-one/506174099
NVIDIA Dual 6 Pin to 8 Pin PCI E Graphic Card Power Cable
https://www.performance-pcs.com/dual-6-pin-pci-express-to-one-8-pin-pci-express-2-0-adapter-cable-sleeved.html
Or order a custom version ^
volkgren
Most GTX 960 have a 6-pin connector. Some have the 8-pin. The only concern I would have with recommending an adapter is the quality of the adapter and the thickness of the wiring used. There's no regulation on that so they could (and sometimes do) have too think of wire and can melt if too much power goes through it.
Best solution is to get a power supply with the proper connectors.
volkgren
Those wires look pretty decent, but you have to get down to the copper to find out the gauge. I really don't think a GTX 960 will present an issue. They aren't very power hungry.
I was looking at this adapter. https://www.amazon.com/GutsParker-6-Pin-Female-8-Pin-Cable/dp/B01N3T6C2K/ref=sr_1_4?ie=UTF8&qid=1549059868&sr=8-4&keywords=6+pin+to+8+pin+adapter
Similar threads
