Archived from groups: alt.comp.periphs.dcameras,aus.photo,rec.photo.digital,rec.photo.equipment.35mm (More info?)
I would sure appreciate hearing from someone who had this problem and FIXED
a similar problem. (Please note -- I have already checked the batteries and
battery contacts. The problem is with the power circuitry.)
I have a C-700 which is about 18 months old. My problem isn't
ordinary battery drain, rather what I suspect to be some kind of short
circuit. Newly inserted batteries, alkaline or (brand new, fully
charged NiMH) re-chargeables only work for a picture or two. I can
open the compartment door, rub the contacts a bit, and get maybe one
more picture, maybe not.
I posted this query about a month ago, and got a suggestion clean the
contacts, check the springs, etc. I have done this and the contact points
are all good & clean. No change in performance.
Already checked the obvious -- tried several new batteries and all act the
same, batteries are not in backwards, etc. The problem is with the camera,
I know that for sure.
Thanks in advance!
Fred
Thanks in advance!
Fred
