[SOLVED] Power question for Nvidia Geforce GTX 750 Ti
Dec 4, 2020
Hi guys
I have a doubt regarding the power that the Nvidia Geforce GTX 750 Ti needs.
I got one Nvidia GTX 750 Ti for free and I wanted to mount it on my PC but I'm not sure if my power supply can handle this GPU.
My power supply is a MAXPOWER 650W/350W Model no. FATX650MP
My build is
Asus PRIME Q370M-C (LGA1151)
Intel Core i7-9700 CPU @ 3.00GHz
RAM 16 GB
Can I put the GTX 750 Ti on the PC without a problem it will work or need another power supply?
Thanks the experts who can help me :)
I would not risk my system with that PSU. It has MAX 12v output 312W and continuous 192W.
Although you are not using it with a power hungry GPU, it's a disaster waiting to happen.
According to nvidia specs, the GTX750ti only draws 60w.
If your card is a factory overclocked version needing aux 6 pin power, that might be different.
Go ahead and use it without worries.
But, as others have indicated, your psu may not be a high quality unit.
Plan on investing in a top quality unit that will serve you for many future upgrades.
The card doesn't need aux 6 pin power, is just attached to the board.
I don’t know anymore. lol
I’ve read a lot of things some say not a problem others say definitely no.
I don't want to compromise any of the other components, the pc is relatively new.
Some versions of 750 Ti do need a 6-pin connector. The connector on those is on the end of the card rather than on the top, unlike most other video cards with external power.
