Power question on build
tbonez3858
31
I'm almost finished with my build and have a power question..I have a phantek luxe case that has a fan controller and LEDs. My phantek CPU cooler is plugged into the mother boards CPU fan power supply. The Phantek case fan controller has a tag that states that it needs to be plugged into the CPU fan power supply. I have several system fan power supplies on my motherboard. Which one should be plugged in the the CPU fan on the motherboard and which one needs to be plugged into the system fan?
Thanks in advance for anyone that can help!
Only connect the fan controller to the CPU fan header if you want it to control all the case fans as the CPU temps changes. This will cause ALL fans to speed up when the CPU in under load. Some find this very annoying and most manually control the case fans and let the motherboard ONLY control the CPU fan.
Thanks for the input on the fan operation. I definitely think this would be annoying...I'm assuming if I plug the cases sata power connections the fans would come on and stay on, correct?
I called the manufacturer. They told me to plug the phantek CPU cooler into the fan hub and the fan hub into the CPU fan power slot. It working like a charm so far!
Thanks for all of your help and information. Its greatly appreciated.
No problem. The "controller" is not a controller. It is just a hub. ANY fans you connect to it will not operate as if they are connected to the CPU header and will change speeds frequently.
If you want to avoid this. Connect the rest of the case fans to the sys_fan headers on the motherboard and manually set their speed.
